- rrupertExplorer
salem wrote:
Service guy told me it's a good idea to use the propane a few times while camping even if you're on electricity. Especially if the shower is used by multiple people (such as kids) because it heats the water faster. Plus, it keeps the system in working order.
That's a good suggestion. - salemExplorerService guy told me it's a good idea to use the propane a few times while camping even if you're on electricity. Especially if the shower is used by multiple people (such as kids) because it heats the water faster. Plus, it keeps the system in working order.
- 2oldmanExplorer IIBoth are fine. Electric at night please, if you run it all night and have neighbors.
My propane heats it much hotter, so I do that 15 minutes before dishwashing. - RbertalottoExplorerThank you!
- rrupertExplorerYes you can do that, especially if you want to get the water heated sooner or there is high usage. Otherwise, you would probably want to just use the AC mode to conserve your LP gas supply.
- SoundGuyExplorer
Rbertalotto wrote:
When hooked up to shore power, do you run the hot water heater electric AC AND the propane? Does this afford faster recovery?
Yes. Your choice. ;)
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 21, 2026
