joe0508's avatar
joe0508
hot water dispenser
I have one of those instant hot water dispensers located on my kitchen sink.The other day i hooked it up.I plugged it up and left my hot water heater on.A while went by and i noticed my hot water heater was leaking on the outside.Is there a rule that you cant have the hot water tank on at the same time as the instant hot.
  • Sounds like the 'instant hot' hot water backflowed into water heater causing the PRV to leak.
    A check valve on line to instant hot should solve that.
    Course I don't know how you have it plumbed.....
    It could have just been because you lost the 'air gap' in top of water heater tank.
    And when water heater made hot water IT caused the PRV to leak.
    To re-establish air gap
    Turn off water supply
    Open closet facet Hot side to relieve pressure
    Open PRV via lever.... (CAUTION WATER COULD BE SCALDING) when water stops flowing out let it snap closed
    Turn on water supply
    Close faucet
    ON EDIT:
    This is the same problem you posted about early.
    You also posted you have three valves on water heater......3 valve system don't use check valves.
    You need a check valve to stop backflow from instant hot
