Picinisco
Oct 06, 2018Explorer
wa8yxm wrote:
IF it works on gas but not on electric here is the test set up. NOTE that by replacign the relay you may have covered one step.
Hook a volt meter or test light across the relay coil. IF you see battery voltage or light lights.. Control board is good. new relay is bad
Battery voltage present. Returned relay. Ordered new one.
Thanks for your help
