boogie_4wheel
Oct 08, 2013Explorer
Bad thermocouple? Should be 'in' the flame. Is used to sense that the burner is actually lit and if it is not lit (or the thermocouple is bad) then it will shut off the gas supply. You could also try scrubbing the thermocouple with a wire brush or sos pad to knock off the soot buildup that could be on the end.
Poor air supply? Run it with the door open, does this help any?
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
