Hello,been gone for a while but back and back to the RV. Question I have has got me stumped. Hot water heater is gas,fires up and heating water. By pass is closed and when I open shower I get cold com...
You stated the bypass is closed. Double check the bypass valve positions because it sounds like you have the water heater bypassed like when winterizing. The valve may have three positions vice two. Could be two directions AND off. If the position of the two valves were mismatched, that would cause no hot water flow, too.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
