socal's avatar
socal
Hot water issues
Hello,been gone for a while but back and back to the RV. Question I have has got me stumped. Hot water heater is gas,fires up and heating water. By pass is closed and when I open shower I get cold coming from both handles. I have let the hot run for at least 2 gallons but still no hot water from shower or faucets. Pump only cycles when I open faucet. Suggestions please. Thanks. David
  • bob213 wrote:
    socal...just make sure the handles for the outside shower are in the "off" position. If left in the on position(even without flow) they will act as a mixing valve and cool your hot water.
    Ok I'll check it out.
  • socal...just make sure the handles for the outside shower are in the "off" position. If left in the on position(even without flow) they will act as a mixing valve and cool your hot water.
  • enblethen wrote:
    If equipped make sure mix valve is closed on outside shower.
    Verify water heater bypass is actually closed. Make sure other valves on water heater are open.
    Mix valve? Not familiar with that valve but do have an out side shower. I'll check the shower. Where might the mix valve be located? Thanks.
  • If equipped make sure mix valve is closed on outside shower.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
