Sam_Spade
Sep 19, 2016Explorer
I discovered the hard way (after paying for a replacement to be installed).....
That when my water heater initially heats up, if you are on the pump and it is ON and all the faucets remain closed during the heat-up (about a half an hour)......the extra pressure of the heated water is enough to make even a properly operating relief valve leak a little bit.
You can prevent that by shutting off the pump until the water heats up and crack a faucet open.
And let's hope that the amount of muscle required to remove the valve won't also damage the tank.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
