Old-Biscuit
Sep 19, 2016Explorer III
15 yrs old so chances are T&P Relief Valve has built up enough scale that it is NOT a matter of re-establishing the air pocket. Time to replace.
15 yrs old it is well stuck
Try 'tightening' first then try removing. Might have to work back/forth to get it to break free.
Remove the exhaust shield so you can get better access.
And if you have a propane torch slightly heat tank area around the valve...but stay away from valve...it is brass and will absorb heat quickly (making it harder to remove)
Use a breaker bar for extra leverage to remove old one.
15 yr old T&P is a 1/2" NPT-------Atwood changed to 3/4" NPT when they changed design (2004)
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
