darsben1
Sep 19, 2016Explorer
ernie1 wrote:
Darsben 1
Is it really ok to get some PB Blaster inside the water heater? You ever smell the stuff? I wouldn't want that stuff in my heated water supply.
It has not bothered me but YMMV. If you want do not spray with the valve open.
I guess a little does get in but the hot water will wash the PB Blaster out or if it works you can heat the water in the tank and then drain it to flush out the tank. If the valve is stuck I would do it an a heart beat to avoid ruining tank. If it does not work once the valve is off run water to rinse tank if you think the PB Blaster smell if any would be objectionable.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
