DrewE
Oct 10, 2016Explorer III
Lenny K wrote:j-d wrote:
If that "4-inch tube" was the probe that goes into the tank, normal for the new one to wobble.
Opening the pop-off on a TP Valve that has any age at all on it, usually means it'll drip afterwards. It's a feature I don't "test."
Must take you a long time to drain the water from the hot water tank when you want to flush out your tank. Or do you flush your tank?
If there's no check valve at the outlet, opening a hot water tap will allow it to drain as quickly as it would when opening the relief valve. Either one prevents the formation of a vacuum in the tank.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
