mmarti0914_ExplorerDec 08, 2015Hot water tank drain hole is strippedMy Rv has a Suburban hot water tank with an anode rod. It is getting difficult to screw the anode rod in and I belive the drain hole is starting to get stripped or cross threaded. Any suggestions? M...Show More
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
Related ContentWater pump?Grey water tank won't drain completelyHouse battery drainWhy no hot water?Fresh water drain
