Ranger_Smith
Oct 12, 2019Explorer
You can check it with an OHM meter with power off. Also if you have a volt meter you can see if you are getting 120 vac at the element terminals with power on. You will only see the voltage there if the unit is trying to make hot water. It won't be there all the time. You can get the element at home depot or lowes for less than 20 bucks.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
