homefor2
Jan 25, 2014Explorer
pappcam wrote:homefor2 wrote:
[img][/img]I have an Atwood 6 gallon propane/electric HW tank that will not run on electricity. I checked the breaker, tried the off-on switch and still can't get it to work. There is a panel in the outside access that says "push to reset" but it does not feel like it does anything. I have a multi-meter but i'm not sure what or where to test for power. Help please.
Have you ever turned on the electric element when the tank was empty? It takes just a second or two to fry the element if you did.
Just had the camper for a short time and don't remember turning it on without water but it's possible. I need to check for power at the connections for the element but I'm not sure where they are. Under the plastic square marked "press to reset" ?
