tvman44
Jan 25, 2014Explorer
Had the same problem a couple of weeks ago with my 10 gal Atwood. Mine was the relay. Use your meter to see if you are getting 120VAC to the heating element, if so then your element is gone. If not see if you are getting 12VDC to the relay near the element, if so then you have a bad relay. :)
