Old-Biscuit
Jan 25, 2014Explorer III
Is this in your 2007 Arctic Fox Camper?
See in 2003 Atwood combined the t-stats (one set for both gas & electric) and did away with the on/off switch on rear cover and went to a 12V DC relay to activate the 120V AC to element. Prior to that the electric had it's own set of 120V AC t-stats located on rear of tank with element. Gas set of t-stats were in outside compartment.
The electric element is on rear of tank under a cover.
The 'push to reset' suggested a Suburban as they have resettable high temp t-stats in outside compartment under a cover. The electric element is also in outside compartment under/behind gas valve. Junction boxes on side of tank for AC & DC power connections.
