STBRetired
Apr 29, 2019Explorer
Do you have a multimeter? You need to check for voltage at the gas valve when it fails to send gas to the burner. If there is voltage at the gas valve but no gas flow, that would indicate a failed valve. If there is no voltage at the gas valve while the igniter is sparking, that would indicate a control board failure.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
