theoldwizard1
Oct 19, 2020Explorer II
What you want is a DC-DC battery charger. Just make sure that one of the supported "battery chemistries" is SiO2.
Hmmm ... Quick search did not turn up such a beast ! Worst case, run a 1000W inverter off of the engine battery and power your SiO2 battery charger. You probably should wire a relay in so that the inverter is only powered when the engine is running.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 29, 2026
