BFL13
Oct 22, 2020Explorer II
theoldwizard1 wrote:shastagary wrote:
if you wanted to keep the ability to charge wit your alternator one of these would do it properly
Victron Energy Orion-Tr Smart 12/12-Volt 18 amp 220-Watt DC-DC Charger
If I have understand the manual for this charger correctly, all charging voltage are programable ! This is exactly what you want !
The SiO2 charging voltages are the same as ordinary batteries, so no worries. It is just the amps being too high I was concerned about with alternator charging. Turns out that is no problem with the 7-pin wiring limiting the amps.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 29, 2026
