MEXICOWANDERER
Oct 26, 2020Explorer
Simple R limiting is cheap and foolproof. From the battery splitter run smaller AWG. 10, 12, 14, whatever gets the job done. Use cross linked insulated wire.
E=I/R Control. Worse case for safe voltage drop. Determine length present then max amperage allowance for load. You can cheat and use an ohms per Mil chart then fractionalize to fit. But you MUST USE cross link insulated wire.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 29, 2026
