BFL13
Oct 29, 2020Explorer II
Sterling says about their $89 Alternator Protection Device:
"If the spike is excessively rough, it can lead to APD damage (which can’t be fixed) but, your alternator / regulator has been protected."
(Link in earlier post)
Mex said:
"I read the description in the link and it gives zero justification as to why voltage would surge in an automotive circuit. Load dump occurs when a substantial load is utterly cut off. If the Gizmo is connected closer than the break in the load path, say goodbye to the gizmo."
I gather that substantial load being cut off is your Li BMS doing a shut off?
This all started when I read that guy's post in the Class C forum where Battleborn Li apparently convinced them they needed the Sterling DC-DC gizmo to go along with having Li house batts. and said it would protect against "surge" too. (The poster might have been confused a bit ?)
Several members of this forum have BB Li drop-ins, so I would think they would be curious about this. BB has a chat. (hint) Please post here anything you learn from BB that would add to understanding what this is all about. Thanks.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
