Oasisbob
Nov 04, 2013Explorer
Your house batteries should charge as you drive. Start your engine and put a volt meter on the battery leads. Your voltage should drop when the motor is turned off. If not there is a problem. Best of luck
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
