Nutinelse2do
Dec 18, 2022Explorer
enblethen wrote:
Start the rig and let it run for a few minutes. Check across the small terminals for 12-volts DC. If not present it could be a blown fuse in the battery control center. OOPS! the small terminal with engine running only should have 12-volts DC.
The only time that the small terminal on top has 12v is when the battery boost button is engaged.
I do not see any fuses for the chassis blown they all have continuity, as well as all the fuses in the converter bay
Again, thanks for all the help, this is progress...
Richard
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
