RLS7201
Nov 22, 2015Explorer II
You do not have a diode system. Your system is controlled by a circuit board in the Battery Control Center (BCC). The isolator relay is in the BCC. Early on Fleetwood mounter the BCC under the hood on the driver side. Yours may be else where. Have some one push the E start button and listen for the relay to click. All indications are, your circuit board has failed. For further help and wiring prints, post your problem here. "Old Bounder" will jump in with better information then I can supply. "Old Bounder" (lou) is the ultimate authority on Fleetwood's BCC. Trust what he says.
Richard
95 Bounder
32H F53
Richard
95 Bounder
32H F53
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
