dougrainer
Sep 16, 2013Nomad
1997, the odds are in the drivers side rear between the frame rail and the Chassis battery box. Is the chassis battery box in the drivers side rear compsrtment? Tiffin just used a standard 3 post solenoid. 2 large posts and 1 small post from the Ignition side 12 volt power. The solenoid was grounded to the chassis frame. Until you fix it, just run the genset in transit to keep the coach batteries up. Doug
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
