luckydog3550
Sep 17, 2013Explorer
dougrainer wrote:
1997, the odds are in the drivers side rear between the frame rail and the Chassis battery box. Is the chassis battery box in the drivers side rear compsrtment? Tiffin just used a standard 3 post solenoid. 2 large posts and 1 small post from the Ignition side 12 volt power. The solenoid was grounded to the chassis frame. Until you fix it, just run the genset in transit to keep the coach batteries up. Doug
Thank you, I believe I found it. Chassis battery box is located on the passenger side. The solenoid is located on the side of the battery box. It is getting 14V to the top lug with the coach running but the bottom only has 12.5V (same as coach batteries are putting out). Is this my problem? Thanks again
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
