Vulcan_Rider
Jul 18, 2015Explorer
What he said.
FOUR batteries ??
If they are 4 12 volts in parallel AND one of them still reads 12 volts, you could leave it connected. The others definitely should not be used and if they are 6 volts in a series-parallel arrangement, they ALL need to be disconnected.
If you have a "battery disconnect" switch, that should do the trick without taking anything apart.
AGM type batteries should be a good choice for replacements.....as they are sealed and usually can withstand neglect much better than the old wet cells.
FOUR batteries ??
