Grit_dog
Feb 20, 2022Trailblazer
IAMICHABOD wrote:
When I had the same problem as yours when the engine was running it was not charging the house batteries,after some testing I noticed that the continuous duty solenoid would click but not lock in which is a loud clunk.
After replacing it the problem was solved.
This is where I’d look first. Don’t know much about Cs, nor you switch on the dash, but the intermittent charging (you must have a gauge or display to tell you it charging?) sounds like a loose ground or a disconnect in the charging relay.
