Cherguin's avatar
Cherguin
Explorer III
Dec 31, 2023
Solved
House battery drain
I have a 2018 Coachman Mirada kb35.  I parked it the day after Christmas (6 days ago), shut everything down and turned the house battery switch off.  This morning I go out and the house batteries are...
  • opnspaces's avatar
    Dec 31, 2023
    Two things come to mind.
    1. You have a damaged or dead battery. Battery cells are about 2.1 volt each when fully charged. Your 6 volt batteries each have 3 cells at 2.1 volts. Put two 6 volt batteries together and you have a total of 6 cells (3 cells per battery) x2.1 = 12.6 volts. If you have a single dead cell you will lose 2.1 volts and see 10.5.
    2. It's also possible that your battery disconnect does not completely disconnect all loads from the battery. It's common for manufacturers to leave certain loads separate from the main loads that go through the switch. These parasitic loads can drain a battery in a week or two.
    First take a few pictures of the wires as they are connected to the batteries. Then temporarily disconnect the wire in the middle that joins the two batteries together and take a voltage reading from each battery. Write this number down. Then hook the batteries back together and charge them up fully.
    After charging fully, disconnect the wire in the middle again. Disconnecting this middle wire will both isolate the batteries from each other and isolate them from the coach. Now periodically take voltage readings over the next week and see if any of the batteries are losing significant Voltage.
    If a battery loses voltage down to 4.2 (meaning you lost one cell at 2.1 volts) you need to replace that battery.
    If after a week disconnected your batteries are still fully charged it's time to hook the middle wire back up. Make sure the battery disconnect is set to disconnect the batteries from the RV. Take a voltage reading from the two battery terminals that are hooked to the wires headed into the RV. You should have somewhere around 12.6 volts. Write it down and then check the voltage daily for a week. If the voltage starts dropping your disconnect is not a complete disconnect.
  • crollman's avatar
    crollman
    Jan 01, 2024
    I'll second the words about parasitic loads that remain active when the main switch is off.  I added a cutoff switch right at battery in order to prevent this from happening.
  • Gjac's avatar
    Jan 05, 2024
    I would disconnect the negative cable and set your multimeter to amps connect the two leads between the post and neg cable end and see what your parasitic draw is. If it is several amps or more, you have something on like a light in a storage bay. If less than an amp or so, check your battery it may have a shorted cell or be on its way out. Being that the batteries are a year old, and you already disconnected the neg terminal, when you return from your trip after 6 days take another reading, if they are still fully charged you know something was left on. If you still read 10 volts you know your battery is bad assuming that you fully charged your batteries both times.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
