Sam_Spade
Nov 13, 2015Explorer
Salvo wrote:
This doesn't make sense. When the Onan is running, you should be getting more than 11.8V at the house battery.
First, be sure that a coach battery disconnect switch hasn't been accidentally thrown. That will stop it from charging from ANYTHING.
AND with the engine running, you should see more than 12.7 at the engine battery too.
I'm not sure that "bypassing" anything is a good idea, not knowing exactly what is wrong.
There may be more than one fault at work here.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
