Endlesssummer
Aug 18, 2023Explorer
Auxiliary Start Solenoid Replacement
A while back I needed to use the auxiliary start switch under the dash. The chassis battery was failing. I looked at the old solenoid in the battery compartment and it was hot to touch.
So I replaced it. The new solenoid also is HOT to touch.
Is this normal ?
Also, how can I test to see if this switch is working and will start the MH using the house batteries.
Thank you
Endlesssummer
2006 Fleetwood Jamboree 31M
Is this normal ?
Thank you
Endlesssummer
