enblethen
Aug 18, 2023Nomad
A new relay contacts should be good. If it cools down it is excessive load through contacts. If relay coil is energized and it still gets hot, the coil is issue and good chance it is still not continuous duty. Make and model of replacement relay?
You can energize aux relay by operating switch and it should have a pronounced loud click.
It should also have same click when chassis battery is charged, and battery control center energizes relay to charge coach battery(ies).
