Harvey51
Nov 14, 2015Explorer
Easy to tell if a poor connection or wire is dropping the voltage - disconnect the charging wire from the house battery. With no current flowing, a resistance will not cause a voltage drop between the solenoid and the end of the disconnected wire. Connect again and a drop in voltage indicates current flowing through a resistance between the measuring points. Could be in ground connections.
Looks like alternator trouble to me, too. I would put a voltmeter across the engine battery and watch while someone starts the engine. The voltage should initially be well over 14 for a few minutes.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
