ksg5000
Dec 08, 2014Explorer II
Have you battery tested - most tire/auto parts places will load test for free. Also check for defective fuse/breaker near battery (google "auto reset breaker" for pic as they don't look like typical fuse/breaker). Also - double check and make sure you haven't accidentally toggled the battery disconnect switch.
Almost all the modern coverters will power the rig if your battery is removed/disconnected/bad - that would explain why your rig does OK when connected to shore power.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 10, 2026
