MrWizard
Apr 26, 2015Moderator
what is your fridge and where do you get the 2.3 amp number
2.3 amps at 12.3v = 28.3 watts, 10hrs = 23 ampHrs used
this LP or electric, 28w is low power for electric, a little high for control board and lp valve use
2.3v at 120vac = 283 watts, which is what an electric heating element might use for an RV absorption fridge
NEVER run an RV fridge on battery power, except with engine running
with that kind of power draw you need a very large battery bank
a 2way or 3way fridge in a "B" should be on propane , you can use electric mode
IF you are shore power, and only when on shore power
please provide FULL info from fridge, and what mode you are using
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
