NinerBikes
Apr 27, 2015Explorer
DAS26miles wrote:
I use my Renogy solar 100 watt suitcase to get the higher volts needed to top charge my Interstate's. Which controller do you have coming with your flex panels? Hope you are getting this one, Viewstar 20 amp the cheaper one doesn't have equalization. I set my equalization mode up to 16.3 volts and the boost charge to 15.4 volts. PM me if you want to know how to do it, it's a special way of setting the parameters that Renogy told me.
Why don't you post up the method that Renogy gave you to set the parameters here?
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
