edingeorgia's avatar
edingeorgia
House Battery Problems...
Our new-to-us 2001 Coachmen  Leprechaun has an electrical  issue that has me stumped. The house battery and converter that it came with where not producing adequate  voltage and an RV tech that was working on something  else  told me to replace both and my problems  should go away. I put in a Powermax PM3-55 and a couple good lead-acid batteries. Should have been good, right? While plugged in to shore power (sitting in our driveway) the coach  voltage started  to drop off and the new batteries  were getting  discharged. Testing with the batteries  disconnected, I get about 12.6 vdc coming out of the converter, while lights, fan and fridge are running. When hooked to the coach load, house voltage drops down to about 11.6 vdc. I traced it back  to the fuse panel  under the bed hoping to isolate/identify (maybe) a ghost load or high resistance short to ground.  Nope. A good 12.6 vdc feed is going to the fuse panel,  but when I connect it to the fuse panel, it drops to1 11.6 vdc. Pulling out one fuse at a time, I expected  to see which circuit is pulling it down. Again, nope. It stayed low throughout that exercise.
So....I'm stumped.
Is my brand-new converter  bad?
And can anyone  tell me how a battery is supposed to charge while it is wired in parallel to the system load?
Should I change the setting on the converter to a constant  voltage instead  of the fancy 3-stage charging?
Any help would be much appreciated.
  • 3 stage charging will still be above the voltage you are seeing, the only thing that could be wonky if the converter tests out fine is that the voltage is manually turned down.
    where are you measuring the voltage at? and when you say testing with the batteries disconnected is that all batteries, so no batteries connected to anything?
    and I just want to make sure I understand your post right, is it normal when you are just on the house batteries but when you connect the coach batteries then you have issues?
  • As StirCrazy posts from the Powermax manual you should be getting 14.6v from the converter with the all the positive wires on the batteries disconnected. Test it right at the converter first to verify what you have. You can also use an extension cord from your garage to the converter to remove any and all doubts about the RV causing an issue.
    I love being able to post when I have basically the same equipment. I have a Powermax PM3-45 vs your Powermax PM3-55 but the mechanics are the same.  Here's a picture from my Powermax  that I just took for this post. If you're not getting ~14.6v like this then you have a problem with the converter.
    • valhalla360's avatar
      valhalla360
      Navigator
      I have the 35amp version and there is an adjustment for the voltage, so if it's putting out 12.6v, it might just have gotten reduced.
  • Missed the testing with out the battery the way you wrote it is a little confusing.   so you still need to test the converter with no loads on the converter at all, so that doesn't mean just unhooking the battery cables as you have seen you can still run 12V with out the batteries.  basically unhooking the output of the converter and testing directly.
    here is how you test it from the manual
    TEST. First, disconnect all loads and battery on the Converter/Charger by removing all 12 VDC connections from +  or POS . Second,
    attach a multimeter instrument between the positive and negative terminals of the Converter/Charger. Then energize the 120 VAC converter
    circuit. Test for proper output power using the multimeter. Measure the output voltage from the positive and negative terminals. The voltage
    should read 14.6 +/- 0.2 VDC. Add 12 VDC load connections to about 2/3 of the rated capacity of the converter. Recheck the voltage, which
    should remain approximately the same as at no load. NOTE: If the chargers output voltage is set below the battery voltage the charge will
    not charge plus the LED will not come on.
    • Grit_dog's avatar
      Grit_dog
      Trailblazer
      He can run the fridge fan etc with no batteries at 12.6V. Why would you say the converter isn’t putting out any power?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
