mena661
Jun 25, 2013Explorer
MEXICOWANDERER wrote:None of the converters will. I've tried three different one's (borrowed WFCO 55 amp cause mine wouldn't boost, Paramode 55 amp that actually did 58 amps and IOTA 55 amp that does 53 amps). All required supplemental charging using another unit. They do get close though, close enough to make you think batteries are fully charged and the IOTA and PD's occasional stirring probably removes some sulfation or eventually charges close to full while removing some sulfation. At least that's my theory. I do enjoy the IOTA's occasional 15 minute, 14.7V stirring. It saves me having to do it manually. Maybe some of the higher end programmable inverter/chargers can get there. Don't know. I don't own one to test one out.
ARE THERE ANY so-called smart chargers around that are plug-and-play?
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
