RJsfishin
Jun 25, 2013Explorer
Your old converter is probably built into the bottom part of the electrical panel. I doubt the 9245 will fit in there. If you have room alongside somewhere, no problem, just connect the pos & neg cables. If you don't have room for the 9245 stand alone model, you will need to get the same converter in a different model # designed for installing in the bottom of the electric panel.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
