Unyalli
Jun 26, 2013Explorer
RJsfishin wrote:Agreeing with you. On this subject would it be better to disconnect the built in converter/charger and install a quality battery charger close to the battery?
Yes, a converter is nothing more than a glorified battery charger, and hook up is exactly the same.
In my Rockwood the WFCO 8955 power center is located around 15 to 20 foot of 10 gauge wire from my batteries. Disconnecting the built in converter would not remove power from the distribution panel would it? If not I would rather get a good adjustable 3 or 4 stage battery charger and mount it close to the batteries with 6 or 4 gauge wire. What say you?
Jeff
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
