xzyHollyxyz
Jul 09, 2013Explorer
The whole "pigtail" was just connected to the old converter with one wire. That's what I snipped this morning. Hopefully, photos I took yesterday will show me where to hook up the other wire. If not, I'll be back here!! :(
The pigtail had a wire nut connecting it to something on the old converter - so, is that the second one?
smkettner wrote:
The pin goes into the breaker empty slot adjacent to the other black wire.
Looks like you cut both leads from that pin :( That is OK, now you need two wire nuts. One to connect to the new converter. And the other goes back onto the other existing circuit.
That 10-30 & 40-50 lable on the breaker side is just a diagram to show how far back to strip the insulation. Yours is a 15a breaker so you follow the first if you were inserting a copper wire. But since you are inserting a pin it does not even apply.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 01, 2026
