ajriding
Feb 25, 2019Explorer II
Rvpapa wrote:
Glass in a threaded hub on the tank. Cut off a section of vent stack in closet. Install male threaded end on cut-off. Trim to appropriate length. Screw into tank using sealer on threads. Join to stack with M-J clamp.
Art
That's why I come to the forum. Sounds perfect, thanks.
threaded pvc fitting, fiberglassed in. Little messy, but does the job.
This is actually better than original since it can be removed without cutting or breaking if tank needs to come back out.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
