- landyacht318ExplorerI use a Drok voltage bucker on a 1.3 amp 180MM computer fan. The hub got too hot and stinky at full speed when fed voltages over 13.
I limit it to 11 volts and it has been working well for a long time now. - RJsfishinExplorerBeen RV'n over 40 years,....never needed any voltage regulation then, don't need any now, and I'd bet I won't never need any.
But then, I don't cremate my batteries either. Batteries don't ever need over 15 volts, and mine don't need over 14.4. But I know, ya gotta do what ya "think" ya gotta do. - CJW8Explorer
smkettner wrote:
How about a sticker next to the equalize button.
"Isolate Battery Before Equalizing"
Never read a post where a random bad converter went over 14.4 volts.
That's no fun but you are probably right.
Noted on the failure but a rare alternator failure could go high. - CJW8ExplorerAfter this discussion, I started thinking a relay that was voltage sensitive with an adjustable setpoint. A quick search didn't turn up anything but I did find this It is a Morningstar relay driver with 4 outputs and is programmable via RS232. This, with inexpensive automotive relays in the right places would do the trick I think.
- CJW8ExplorerIf the never exceed voltage on the refer board is 15.4V, I suspect I would not be doing it any good over time to be sending it 15V.
Easiest is to pull fuses on the furnace and refer as mentioned and as I did yesterday. The refer board failed for unknown reasons and I am now fairly certain I equalized while it was on. Failure wasn't at that time but within 2 weeks of equalizing. (I really should keep a log book). We'll never know the cause of failure.
I equalized because I like to occasionally shut off my converter and check my battery capacity. A boondock test if you will. I have 3 each group 24 batteries, new in July. I shut off the converter and let the batteries stabilize at 12.7. I used some lighting (all LED). After two furnace cycles voltage holding 12.4 just before the third furnace cycle. I felt it wouldn't take very many cycles before the voltage was at 12 volts. It certainly wouldn't get me through the night. My battery tools (hydrometer and battery capacitance tester) are home in AZ and I am working out of my toy hauler in NM. I felt it wouldn't hurt to equalize while the sun was high. - How about a sticker next to the equalize button.
Never read a post where a random bad converter went over 14.4 volts. - wa8yxmExplorer IIIIt has been a LONG time since I saw the article but basically it was a Progressive Industries "Surge Guard" for DC.. I can describe the cirtuit, or rather it's elements, but I can not build it from memory
You have two voltage comparators(SP?) these are devices which compare the voltage on the "Sense" lead to a standard (usualy 5 volts) on board. They output HIGHER or LOWER (1 or zero depending on the input voltage
One is set to like 11 or 12 volts (low voltage cut off, in your case this one is optional) the other is set to like 15 (high voltage cut off.
The output of these drive a RELAY.. Since one should be high and one low when the voltage is right the relay pulls in and power is sent on to the loads.
If the voltage goes HIGH or LOW then both of them will have "Same State" this results in the voltage across the relay coil being zero (EIthe 12 and 12 relative to ground or 0/0 but either way ZERO refernce to the other terminal)
Any decent electronics technician can make such a device. - gatorcqExplorerIF your RV chassis engine alternator charges your coach batteries, what happens when your alternator fails? Can go as high as 18 volts? How many known failures have you had and this does not mean someone told you about someone. How many of you have really experience a failure due to an over voltage. Once we have a realistic number then we can do a MTBF due to a high voltage
- Old-BiscuitExplorer IIIWhy the frequent equalization?
Last Nov and now.....
I equalize twice a year.
And when I do I pull DC fuses for water heater, fridge and furnace - GordonThreeExplorerAsk your solar vendor if they can program the aux output on the charge controller to power a solenoid. put the solenoid between your batteries and low-current DC load panel. program the solar controller to turn off the solenoid during equalize periods.
many of the solar controllers have programmable aux outputs, just a matter of pressing the right buttons, jumpers, etc.
Having RV issues? Connect with others who have been in your shoes.24,353 PostsLatest Activity: Jan 23, 2026
