dougrainer
Aug 11, 2020Nomad
2oldman wrote:dougrainer wrote:I measured it with indoor air at 90 so there was no question. I taped thermometers to the intake and outtake. yes, they were working correctly. The output air is always cold.
In your temp of 55 degrees, then the intake at the return filter will be 73 to 77 degreesug
If you put your hand in your output, isn't it cold?
You are saying a 35 degree difference?????? NO WAY. What type thermometer are you using? Digital or Dial. If DIAL, have you calibrated them? To calibrate you stick them in a glass of icewater for a few minutes. You then turn the adjustment to 32 degrees. Trick learned from Dairy Farmer who was a customer. Doug
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
