smthbros
Aug 15, 2020Explorer
poppa wrote:joshuajim wrote:less sensible cooling, still removing latent heat
The other factor to consider is humidity. The higher it is the less cooling you will get.
Since you mentioned "sensible cooling" and "latent heat", and that you agree that the only correct way to evaluate the performance of an air conditioner is to measure the amp draw on the compressor and compare that to the expected amp draw for the temperature it is operating at, perhaps you can explain how to account for "latent heat" removal with that method?
As far as I have noticed on this forum, nobody else has been able to do so.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
