neu's avatar
neu
How critical is it to have a perfectly level trailer?
Hello everyone,
I bought an adjustable trailer hitch, but I miscalculated and the maximum height is not enough to level the trailer. This hitch raises the height by 5 1/4 inches, but based on my calculations, I need an additional 1-2 inches of height to level the trailer. Is this critical or can I still tow the trailer as is?
UPDATE: I've read a few articles that say that I should better level it properly...
I don't know how to remove this question from the forum
  • Several things.. I think you are talking about it's towing level not parked once you get to your site.
    Looks like you don't even have your propane cylinders installed yet. Those are going to add tongue weight.
    You probably don't have the vehicle loaded for a weekend camping trip. People, stuff in the back, etc. Is the trailer loaded ready to camp too?
    The receiver on the vehicle is probably not rated for a weight distributing hitch setup, neither is the vehicle, as it's just a uni-body SUV by the looks of it.
    Your chains are still dragging, so you can 'twist' the links up to take up some of the length off, or have them cut to length and put on new hooks.
    Might still be chewing off more than the vehicle can handle, but at least you are doing your homework first!
    Good luck! Mitch
  • BB_TX wrote:
    You don't say what you are towing with, or what you are towing. My question: is the trailer tongue weight too much for your tow vehicle making the tow vehicle rear sag too much. You pictures don't show enough to tell.
    ^~this
    While level is a general goal, it may be a symptom rather than a core issue.
  • You don't say what you are towing with, or what you are towing. My question: is the trailer tongue weight too much for your tow vehicle making the tow vehicle rear sag too much. You pictures don't show enough to tell.
  • LEVEL, or straight alignment between the vehicle and trailer gives you the strongest connection. Besides being level. You can "bend" a V. Harder to bend a -------- straight line connection. If you have to have a panic stop, you want the strongest connection. YES, you need a equalizer hitch connection. More expensive, but the SAFEST way to tow a trailer regardless of length or weight. Doug
  • If I understand your post you are wondering about how level it is when towing instead of parked. Parked, you want it level. Roads aren't level, at least not for very long. That said, it may affect your tow vehicle and it's capacity and how it handles.
  • You better get an equalizing hitch! I'll bet you are over the towing capacity of you vehicle.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Ok there are a few reasons to want it more or less Level.. Perfect.. Well read on.
    An RV Absorption Cooling Unit (Fridge) likes to be within 3 Degrees of level
    What is 3 Degrees Well about 5" side to side. (that's a lot of slope)
    Or 1 foot end to end for a 20' Trailer
    Air conditioners condense moisture out of the air. if the Rig is "nose down" that condensate (As it is Tecnically called) may Drip down into the Living space instead of out on the roof to the ground.
    And you won't be comfortable sleeping
    Also if it's not "Square" the door may not open/close properly.
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
