pianotuna
Aug 04, 2018Nomad III
Do your capacity test at c/20 (5 amps for each 100 amp-hours of storage @ 12 volts). That would be about a 40 watt 120 volt bulb on the inverter, allowing for inverter losses. As the battery bank discharges the inverter may attempt to support the voltage by drawing more and more amps.
me2 wrote:
1 200 watt inverter and a 120V "load". I'm using 2 x 75 watt incandescent light bulbs on switches.
Multimeter
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
