Sandy___Shirley's avatar
Oct 17, 2013
How do I fix my Keystone slide, they won’t do it!
I realize my RV is almost 10 years old, but if you look at the webpage I created for their customer service, it is fairly obvious that the problem was in the way it was put together. I guess if they can make them to hold together for one year, it becomes your problem!
My images are high res so I can't show them here! You can see the problem in detail at this webpage, along with the Keystone response: http://www.bitware.com/343L
The bottom corner of the slide was never put together properly. My guess is that the silicone caulk gave way fairly quickly and allowed water into the plywood under the slide with is now black with mold and falls apart easily. Eventually the metal bracket came loose completely and revealed the problem.
Any advice on how to proceed would be appreciated. My current plan is to move the mattress into the living room of the RV and remove the plywood that supports the mattress. Hopefully I will be able to see the extent of the problem once that is done. Not sure how, but if I can I will replace the portion of the plywood that is rotted and support the corner with a 2x4 and find some way to replace the metal corner that fell off.
Again, any suggestions would be appreciated!
  • I think you're right and wrong about this issue. It probably didn't start leaking and separating in '04 or '05 but loosened recently. Yes, it could have been built better.
    This could be the "poster child" for having a maintenance schedule that includes inspection of all areas of the exterior where water could enter. Had the water intrusion been dealt with in a timely manner, there would be a lot less repair work.
  • To do a proper job, you really need to completely remove the slide get it on the bench so to speak and rebuild it properly. Once out you will likely find way more damage than you are seeing now. At least this will give you the opportunity to do the job right. Done too many jobs the hard way. It usually winds up costing me way more time and effort than is required to do it right.
  • ScottG wrote:
    ...I'm sorry but after 10 years there's no way I would expect warranty on damage like this.
    X2...
  • Looks like a combination of water intrusion and perhaps stepping on or otherwise using the slide while it's in, which can loosen the floor and pull it loose from the walls.
    FWIW, I have made a similar mistake by stepping on the floor while the slide was in and damaging a support part underneath. All my own fault of course.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
