wa8yxm
Jul 27, 2015Explorer III
Depends on the lights
On the 4 pin the "odd" one is ground
Then the one next to it is tail light/running lights
Right and left turn/stop are the remaining two (not sure the order
I do not I am thinking that on your trailer either they use the hitch as the ground in which caSe you going to have to adapt.. OR.. they left something off (tail lights perhaps).. In any case I think you are in for work
You will need to identify each wire as to what it feeds. And as I said. not sure if the "odd" one will be tail light or ground.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
