westend
Jul 28, 2015Explorer
Since the camper connector has "DC" embossed on the jacket, there is no reason to believe it has any pinout relationship with a standard 4-way trailer connector. I'd suggest to check continuity with the pins on the connector and frame ground, a running light fixture, any backup lights on the camper, any taillight fixtures, and a wire leading to the battery compartment (should have one of those three colors).
If you want connectivity to the truck, I'd suggest to buy a 4-way "Y" splitter (fairly typical and easy to source) and make a custom pigtail to connect to the camper. You can buy both genders of individual pins to make the pigtail (might even get lucky and find the 3 way connector to modify).
Good luck on your wiring, that's a sweet rig.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
