Old-Biscuit
Mar 05, 2014Explorer III
Well you will need to disconnect hot/cold plumbing on backside of tank
Disconnect electrical connections on electric heating element----backside of tank
Disconnect 12V DC wiring
Disconnect propane line in outside compartment
Then remove all screws in frame and pull unit
Although there doesn't appear to be access to rear of tank there probably is a panel that has to be removed.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
